The issue with one of my units was probably because my old solder station was ready for retirement. Got a new really nice Weller today and reflowed most of the joints on the main board and both units are now operational! Thanks Jeff!jsteiger said:I think that is a little funky. There should be plenty of room on both trimmers to cal the meter in perfectly.Unit7 said:I did that and was able to get one unit perfect and the other almost, because the RV8 hit the bottom and I settled for 2.489V with GR off and 2.235V with GR on. The meter behaves, but Jeff would you say that is close enough, or is there something funky about the RV8 hitting the bottom?
Great news Paul! Thanks for the updateUnit7 said:The issue with one of my units was probably because my old solder station was ready for retirement. Got a new really nice Weller today and reflowed most of the joints on the main board and both units are now operational! Thanks Jeff!jsteiger said:I think that is a little funky. There should be plenty of room on both trimmers to cal the meter in perfectly.Unit7 said:I did that and was able to get one unit perfect and the other almost, because the RV8 hit the bottom and I settled for 2.489V with GR off and 2.235V with GR on. The meter behaves, but Jeff would you say that is close enough, or is there something funky about the RV8 hitting the bottom?
The faceplate should be in place before inserting the meter PCB.Kevinkmny said:Hi guys....
I was doing so great...made it all the way thru the build until the LEDs...
Soldered one side then removed the meter pcb to solder the other side...now I can't get the face plate back on to the front with the LEDs aligned properly and have snapped one of the LEDs in the process...
Any helpful tips?
Thanks in advance!
Yes either that or look for the one or two that are holding things up and straighten them.Kevinkmny said:I wonder if the best solution isn't to remove the existing LEDs and try again...
I have never had trouble with this. The LED leads are very stiff so I have never had them move. I am always pretty careful with them too.Not sure how to prevent the certain movement of the LEDs when you remove the PCM to solder the other side....
No they are not required for the LME49710's. I only added the spot on the PCB in case someone uses a 5534.furn1979 said:I believe 4 x 22p capacitors are missing from the 4 Opamp Adapter Kits. Can I swap them with caps of other value?
