kante1603
ABI?kosi said:In which position will they have the most coloration ? Any tips ?
8)
Doug, I'm not sure I follow you here. Do you mean that with 2.245V at TP10, the LED's are only lit up to the -5 yellow one, the -7 doesn't come on?emrr said:At 20:1, once I trim RV8 to 2.245V it always lands at -5dB GR.
jsteiger said:Do you mean that with 2.245V at TP10, the LED's are only lit up to the -5 yellow one, the -7 doesn't come on?emrr said:At 20:1, once I trim RV8 to 2.245V it always lands at -5dB GR.
What is the DCV at TP10 for each one of those?emrr said:Meter readings for actual -7GR at 20:1, consistent at each attempt to align, up until RV8 hit an end stop.
2:1 -1
4:1 -7
8:1 -7
12:1 -7
20:1 -5
OK. All of the ratio switch and other things aside, the meter is just a simple set of comparators much like any other LM339 style meter. The only difference is that I am using them "backwards". So, once the incoming test voltage drops below the respective comparators reference voltage, that LED will light. If the meter reference string is correct (see the meter test points), no setting on the comp will alter this.emrr said:.... I do have the new docs.
jsteiger said:The fact that 2.245V does not trip the -7 LED tells me that your reference string as shown in the test points doc is not right. Meter point #3 cannot be 2.253V.
Only something funky with the meter board. What's important to note is what the DCV is at TP10 when this unexpected result happens. Just remember, all each individual comparator channel is doing is looking at the reference voltage and the incoming test voltage. Once the test voltage drops just below the reference, that LED will light. That part is pretty straight forward and will never change.emrr said:What would make the 20:1 setting read LESS GR than the lower ratios, with -7 dB actual measured at 20:1?
Well, setting the unit up 20:1, attack/release both full CW/fast, input/output to a resulting 7dB of actual gain reduction, then only changing the ratio switch will alter the amount of GR. This is simply a matter of how the 1176 circuit works. This will not at all change the meter but will change the voltage at TP10, which will change what the meter shows.emrr said:Regardless of meter alignment, if you change ratios and have less actual GR, why would a higher ratio show less (correct or incorrect) GR than the lower ratios?
jsteiger said:Meter LED's aside, with the above typical 7dB of GR setup, when monitoring the output level so that 0dB is showing (+7dB at the input).....
switching to:
12:1 will yield -1.45dB
8:1 will yield -1.94dB
4:1 -1.74dB
2:1 +1.92
No, not necessarily. There are many other things at play like onset of compression and knee. This will change depending on how much GR is taking place. Depending on how much GR is taking place, the opposite will happen.emrr said:Yes, change to a lower ratio will alter the amount of GR to a lesser amount than found at a higher ratio.
This is possible but the if the test voltage going to the meter is 2.245V, then the -7 LED will fire. If not, its a problem on the meter board. No matter what the ratio setting is, if the comp is producing 7dB of gain reduction, TP10 will be 2.245V if all is cal'ed correctly. I have verified this with every ratio setting.I'm wondering if there's something about this particular 20:1 not being right, which would feed the meter incorrect information...
Yes, relative output change. I have added some info to them to clarify.jsteiger said:Meter LED's aside, with the above typical 7dB of GR setup, when monitoring the output level so that 0dB is showing (+7dB at the input).....
switching to:
12:1 will yield -1.45dB (resulting in 8.45dB of GR)
8:1 will yield -1.94dB (resulting in 8.94dB of GR)
4:1 -1.74dB (resulting in 8.74dB of GR)
2:1 +1.92 (resulting in 5.08dB of GR)
Those ratio change dB numbers are relative output change or metered GR? I think I'm reading it as relative output change.
More measurements to do, theorizing isn't revealing anything.
