Bad solder joint somewhere is my guess.
Yes indeed. A short piece of resistor lead will work a treat.PeteJE said:Grayhill stop pins - yes, I lost one, arg. Can I use a very stout piece of wire lead from a component it place of the stop pin?
Thanks for the link, Jeff. That is all I can imagine, maybe not fully seated at first, then swapping back and forth fixed this issue and brought it to working condition.jsteiger said:Are they fully seated? http://classicapi.com/catalog/DOA_Install.php
Congrats,you can sell your 480 or 300 to gain a lot of money for several lovechildren (that's a LARC on the right side in the pic,no?) ;D .......but only if you have a spare one,hahaha!PeteJE said:I have one BIG problem.... I need a second one ASAP, and the store is out for now,- I'll keep checking stock. (also kind of excited for the FC526 too).
kante1603 said:Congrats,you can sell your 480 or 300 to gain a lot of money for several lovechildren (that's a LARC on the right side in the pic,no?) ;D .......but only if you have a spare one,hahaha!PeteJE said:I have one BIG problem.... I need a second one ASAP, and the store is out for now,- I'll keep checking stock. (also kind of excited for the FC526 too).
Did you experience that the LC53 adds fantastic "sound" even when in bypass?
I have them inserted just for that in a lot of scenarios (on a stereobus to grid rid of "digital sound" we have to deal with nowadays)!
Have fun,
Udo.
Don't do that!PeteJE said:Ha! It is a 480L. On that note, although I like them very much, the JLMs may get "traded in" for the FC526......... we'll see.
jaminem said:Hi all, new to this forum - thanks for having me.
Big fan of Jeff's kits and have built several pre-amps now building this EQ.
The CMRR calibration has me stumped.
I got the test jig to make this easier, but to be fair I'm pretty clueless (I play bass)...
I'm out putting a 100hz sine wave from my DAW to my 500 rack.
have the card plugged in, to the rack and the main pcb, put a DMM on as chungers build suggested but got nothing from C to the negative of the large blue cap? I get something from V+?
Can I measure what ever it is i'm supposed to be measuring back at my DAW?
Totally no idea, and the CMRR doc and chungers build don't use the jig, so not even sure how this works?
help!
