stringmike said:since I didn't have a good trimming tool when I made those.
jsteiger said:That is the ground connection for that cap. Since the ground plane is on the other side of the board and the holes are plated thru, it sounds like you have enough solder in the barrel of the hole. To be safe, you could solder a short jumper wire from that lead over to the ground pad of C8. That is the hole that has no visible trace running to it. You could also just heat up that nub of a lead and add a little more solder to what is showing. That is what I would do.![]()
Musepro said:Hi all! I built an LC53. While doing final testing, both the HPF and LPF work and both the HI and LO bands work at all frequencies in shelf/bell.
However, the midrange boost/cut gives me nothing. All components are in their correct places/polarities with known working GAR-2520s in place and I don't see any bridged or cold solder joints.
Anyone have any ideas as to what the issue is? Thanks!
jt burke
jsteiger said:Hmm, well that all checks out. If you have DCR, the inductance will be fine and nothing looks open there.
My next thought is that the stop pins are in the wrong spot on the freq select Grayhill on the LC-EP PCB.
jsteiger said:All switches should only travel to what is designated on the faceplate, not one position further each way. I would imagine those were also moved before the pins went in? Hence 7 positions instead of 5. 12-7=5 so those wipers are also between the wrong sides of the stops pins.
Georg, the inductor won't be the cause since it not being installed is no different than what happens when the EQ is not "ON". The LCR series component strings are lifted from ground when not ON.Tschem said:hello all!
just finished with building 2 units. the first works, the second one too but has around 6 or 7dB less output. this is also the case when the unit is in bypass. i've already interchanged all DOA and DVF from both units but it's still the same. in the second unit there's no L1 4H inductor installed yet, but according to jeff this shouldn't be the problem.
can someone plz help me troubleshooting from here?
thx in advance,
Georg
