Remove A2 (4558 chip) from that pre and measure again.
Yes, this one is easy with only 1 slot open. Plus it's simple for 15 or 18 pin card edge connectors.kante1603 said:When I did my first extender cables I used the protoboards,but they were hard to plug in when say just 1 module slot was open.
Yes, exactly. Simple instructions for CMRR calibration are on the board. All parts will be included with the kit. There is a status LED for the CMRR switch that can't been seen in this pic.The switch and resistors,are they for cmrr (hard to read this printed instructions on the board)?
jsteiger said:All of those status LED's are in a string so if some are backwards, this will happen. Only the working one is the right way around.
jsteiger said:Well, the direction of the LED's will have nothing to do with the audio path so there must be something else going on.
jsteiger said:Well, the LED thing does not make sense to me. The string starts at the lowest LED which is phantom and ends with the polarity LED. When a switch is out or disengaged, it is merely shorting out that particular LED. When the respective switch is pressed, the LED is introduced into the string. So, with the last LED (polarity) illuminated, if pressing any of the lower switches causes the polarity LED to go out, they are in backwards. I can't think of any other reason that this could happen.
As for the audio, start with the usuals. Rack slot, cabling, converter settings and then to swapping the opamps and general trouble shooting that is above in this thread.
Yes! progress but then another glitch. Built the replacement 1731 and now the 2nd VP28 works perfectly. However when swapping the opamps out of the first VP28 (Which was working!) to try them in the 2nd something must of happened. As the 1st VP28 lights up but there is no signal passing through it whatsoever. Don't even get the quick green flash of the signal LED with switching mic in and out while the phantom is engaged or when the lunchbox powers up.jsteiger said:Cool. Glad you are making some progress!
New Soul Rebel said:jsteiger said:Well, when you have phantom on, there is usually a pop or thump when engaging the standard pad. After all, when switching DC there will be some popping. It has always been a standard practice to engage phantom and the like with a pre's output muted by some means or not connected, It really can also be said for the mic/line switch.
Except that there must be something wrong... as I don't get this thump at all on my other VP28's.
Its an almighty thump Jeff... I know what you mean about a pop or thump when engaging mic lines or pads, but this is an unusually big thump! Any other ideas what might be causing this. Like I say, the pre works perfectly in operation. But I want to resolve this.
