Do you mean the 2 pre's are off from each other by .3dB or the output level differs from the input by .3dB?
kante1603 said:Hello and welcome to the forum.
A thin or lacking low frequency signal at a low level indicates a balancing issue most of times.
I'd check transformer wirings and functionality first,seems like a "hot" or "cold" signal part is missing.
Udo.
Udo.
Udo.
jsteiger said:The shaft adapters are not needed as the knobs have an 1/8" hole for the GH's 1/8" shaft. Sounds like they need to be tightened more stoutly.![]()
Unit7 said:You'd have found it if you searched for 2520 instead of 2050http://groupdiy.com/index.php?topic=33970.0
