jsteiger said:Hmm, OK this is the first issue I have heard of with the signal present on the new PCB. If both are acting the same, it is likely the same build error on both or possibly a rack situation? What rack are you using?
Agreed it does suggest the same error. I am using a Radial PowerStrip 500 Series 3-Slot Power Rack. I do have 2 other lunchboxes I can try. An aphex usb 500 and a bento 6. But I have never had any other problems with the radial. Of course that doesn't mean it's not causing the problem.
I guess the question would be what feeds the ic when the 48v button is pressed vs not pressed? As this seems to be related somehow.
I followed the guides by both you and chunger in this thread. Used the BOM provided on the site and carefully separated each part and tested individually with a volt meter taping each part to a piece of paper similar to the way chunger does. Never had any discrepancies. All parts matched up to their respective pcb names. Many builds under my belt. First time I've had a problem.
That said I am a human. Weird that I would repeat the mistake unless there is something I repeated in the guides?? Maybe I am missing something. Thanks for your help.
