Hello,
I'm having a little trouble with a vp28. I built a kit with Litz wire transformers and the pre-built Red Dots. 3 main symptoms:
1) Upon first couple power ups, the green signal LED was constantly lit. I found that it would flicker when pressing the 48v switch. After running signal through it for a few seconds, it no longer does this and works as it should. I guess I'll call that solved?
2) Line mode passes a clean signal, but -10.58db lower than whatI send in. I use Pro Tools to generate a 400hz sine wave at 0dbfs and measured through the vp28 at unity, then with the patch wire straight from the output, patchbay, to the input of the converter (rosetta 800). Signal without the vp28 in the chain comes back clean at 0dbfs.
3) In Mic mode, I can see that it powers my 414xls and it passes a clean signal for a few seconds, then dies out to a very low signal. There is a loud, low rumbling sound in the signal. I have a recording of it if needed.
I tried switching positions and re-seating of my op amps and switching to two of my home-built gar 2520's but the symptoms are identical.
I've switched slots of my Lindell audio 10 space rack but no difference.
I've reflowed every solder joint except the switches on the HPF board, since they were hard to reach once assembled. That will be my task tonight, but if anyone has ideas on something else to check as well, please let me know.
Edit: This is the Rev B, green pcb. I followed the proper BOM
