brewhouse75
New member
- Joined
- Aug 29, 2018
- Messages
- 2
One of my four VP28s has significantly quieter output than the others. Rechecked solder flows and everything looks good. Any suggestions as to where to go from here?
benplayskeys said:Hey Guys,
I have an odd one.
I’ve built over 20 of these preamps and this is the first real issue I’ve had with one.
Here is the setup-
Pro Tools tone generator sending pink noise out into an RND R6 rack. VP28 with the issue is plugged into slot 1.
The main symptom is that the unit passes a very very small signal out (basically nothing at all) in line mode when first turned on. The green LED does not show signal and the pre has to be cranked as well as the output fader to hear any resemblance of sound. I discovered that if I engage the “Mic” switch and immediately disengage it, the Line level input is suddenly working and passing signal at a good level. The odd thing is that when I come back the next day to re-test the same issue is occurring. I have also left it on for somewhere in the ballpark of 15-20 minutes and it suddenly drops out. This could then be fixed by again, engaging and disengaging the “Mic” switch.
Here is the trouble shooting steps I’ve taken.
-re-flow all solder points
-replace the Toneluck switch in the Mic/Line path
-triple check resistors are in the correct position.
-I have placed known working Op Amps in both Fader and Pre positions (Gar as well as SL Red Dots)
-I have also used a known working unit in this chain and it has no issues
Thanks for your help in advance.
-Ben
Yeah, I would suggest using only known to be working opamps to test a new build.resilient said:Built my VP28 today. And it is not working.
I believe it's probably my op amps (also built those). Or one of them, anyway. I've reached out to Scott for some red dots. I've also ordered an extender from CAPI so I can take measurements when they get here. The reason I believe it's my DOAs is because if they're inserted one way, I get a constant signal LED. Switch them around and there's no signal led.
Brandon
There's a Test Points guide posted in the VP28 section of the Support Docs page at the store.resilient said:That makes sense. And I've got two red dots that should be here Wednesday or so. I'll pop those in and see what happens. I'm hopeful that fixes the issue and I can move forward. I'll be back if not. Haha!
Do you have a general troubleshooting guide, Jeff? Specifically what voltages I should see where on the test points provided on the VP28?
Brandon
What opamps are you using and who built them?S-O said:Hey there! Thanks for putting out a rad kit that is super easy to follow! I had very few troubles assembling! The only problems I had were my own fault and were pretty easy to fix!
I have made 2/4 VP28's I bought. Halfway there!
I have one odd issue that may never really be much of a problem in the long run but I would like to see if there is an easy solution. I searched a bit and didn't find anything that matched my problem exactly.
So When I have the VP28 in the CAPI 511-VPR Filtered rack with DB25 cables plugged into it and into my patch bay the green signal LED is on. As soon as patch something in the input or output all is well and it turns off! If I plug headphones in I can hear that something seems to be oscillating.
Maybe something is grounding out or solder bridged but I can't seem to find out where or how! Any input would be rad and appreciated!
jsteiger said:What opamps are you using and who built them?
That said, its quite possible that there is an error on one or more of the opamps so the green signal LED is doing its job due to maybe some noise or oscillations. I would test them with prebuilt or solid known to be working opamps.S-O said:Thanks for the speedy reply!
Lil ol' me built them! Not my first DIY attempt, but one of the more complex projects I have done!
I am using your GAR2520 v4.1 opamps!
jsteiger said:That said, its quite possible that there is an error on one or more of the opamps so the green signal LED is doing its job due to maybe some noise or oscillations. I would test them with prebuilt or solid known to be working opamps.
Try disconnecting the primary leads (PCB labels red and orange) from T2 and see if TP2 comes up to normal.resilient said:Ok, finally got everything put together and took some test measurements.
Here is what I have:
TP1: 110mv
TP2: 109mv
TP3: 192mv
TP4: 53mv
TP5: 53mv
TP6: 53mv
TP7: 54mv
Any thoughts on what I may have screwed up? This is with Lieber red dot op amps, too, FWIW.
Brandon
This should not have changed TP1 at all. Something is strange possibly with your input level?resilient said:Thanks for the reply, Jeff.
This made TP1 379mv and TP2 374mv. All others were 0.
Brandon
OK so the issue is between TP1 and TP2.resilient said:Well I tried again tonight. Verified input was 1.22v and this time I got 111mv at TP1 and 109mv at TP2.
Brandon
