Hi guys,
I'm having a problem with a VP28 unit i built myself. When i am in line mode, pad engaged, there seems to be a substantial increase in the high end when i run tracks through it. I set up Q clone using my daw to verify that and it turns out that when the pad is engaged in line mode, there's kind of a high shelf (see picture). When i am in mic mode though, the frequency response stays flat whether or not the pad is engaged.
Is this something normal ? If not, where should i start as for as troubleshooting ? Bad solder joint, wrong capacitor or resistor value etc...
Here are my test points :
TP1=101mV
TP2=698mV
TP3=1,241V
TP4=305mV
TP5=305mV
TP6=305mV
TP7=642mV
XLR output = 1,233V
Regards,
