Thanks, Jeff.
Can someone give me hand with that ? I've yet to resolve this issue, if it is one.Hi guys,
I'm having a problem with a VP28 unit i built myself. When i am in line mode, pad engaged, there seems to be a substantial increase in the high end when i run tracks through it. I set up Q clone using my daw to verify that and it turns out that when the pad is engaged in line mode, there's kind of a high shelf (see picture). When i am in mic mode though, the frequency response stays flat whether or not the pad is engaged.
Is this something normal ? If not, where should i start as for as troubleshooting ? Bad solder joint, wrong capacitor or resistor value etc...
Here are my test points :
TP1=101mV
TP2=698mV
TP3=1,241V
TP4=305mV
TP5=305mV
TP6=305mV
TP7=642mV
XLR output = 1,233V
Regards,
Using the Mic Pad when in Line mode is not something that ever needs to be done. The Pad is only designed to be used when in Mic mode. The module is essentially flat in Line mode and flat in Mic mode (with or without the Pad engaged).Can someone give me hand with that ? I've yet to resolve this issue, if it is one.
If someone would be kind enough to pass some audio files provided by me in line mode, i would be better positioned to judge if my unit is ok or not.
Please reach out to me if you're open to help me.
Thanks for the lighting fast response Jeff, and thanks for clarifying the pad use.Using the Mic Pad when in Line mode is not something that ever needs to be done. The Pad is only designed to be used when in Mic mode. The module is essentially flat in Line mode and flat in Mic mode (with or without the Pad engaged).
I have never ran a sweep that way. Its putting 2 u-pads in series. If its flat in Line mode and flat in Mic mode with or without pad you are golden!Thanks for the lighting fast response Jeff, and thanks for clarifying the pad use.
I get what you're saying when you say the pad shouldnt ever need to be engaged. It makes sense because in line mode, the incoming signal is line level to begin with. Weirdly though, the frequency response is clearly not flat using my two modules in line mode, pad engaged. I've measured it with Q-Clone in my DAW to confirm what i was hearing.
My units are flat in line mode, pad depressed, so it's reassuring in a way.
Again, not trying to be a pain here, i just want to confirm the units are sounding as they should.
Excellent, thank you mister Steiger!I have never ran a sweep that way. Its putting 2 u-pads in series. If its flat in Line mode and flat in Mic mode with or without pad you are golden!
Thanks for the reply!Así que debes tener un cortocircuito en los rieles fantasma en alguna parte, y si esos dos transistores están calientes, ¿están invertidos? ¿Es el 161 donde pertenece el 141 y viceversa?
Take some hi res photos of the top and bottom of the board and post them.Thanks for the reply!
The 161 and 141 are each in their place, they are not reversed.
It strikes me that when activating the 48v it has burned that part.
What would be the rails of the phantom?
Thanks Jeff for the response! The BC, even though the PR resistances have been burned, can I use them again or is it better to change them?Phantom power does not get anywhere near the opamps so it can only be a coincidence that the R's burned when you engaged phantom. Those 10R's burning up are a tell tale sign of an opamp problem. If the opamps look like the same style of work as the main board then you likely have shorts on them as well.
Its hard to say not knowing what's wrong with the opamp.Thanks Jeff for the response! The BC, even though the PR resistances have been burned, can I use them again or is it better to change them?
Register today and take advantage of membership benefits.
