[BUILD] CAPI VP28~500 Series~2-Stage Preamp~Official Support Thread
Hey! Done building 1 VP28, im getting sound and all the buttons are working functionally, LEDs working, phantom working etc.
have some test results. But the signal is very weak, measuring somewhere -70 to -30 db on my audio interface, with a sm57 and fader and pre gain all the way max. Testpoints 1-5 seem to measure values that are good. but 6-7 not really anything there.
  1. 109mA
  2. 696mA
  3. 1.26V
  4. 307mA
  5. 309mA
  6. 0
  7. 0
Hope someone could help! Thanks.
Between TP5 and TP6 is the HPF PCB so check that along with the 5-pin header and the mini toggle switch as signal passes thru it.
Looks good there, reflowed the solder joints, could it be the op amps? Whats between tp6&7?
If its down at TP6 most likely the issue is between TP5 and TP6.
The fader amp is between TP6 and TP7.
If you aren't testing with 2 known good working opamps then trying to "fix" the module is like a dog chasing its tail.
Ah ok, too bad. Might have to buy some preassembled opamps then!
You can remove the fader amp and check for ACV at that opamp's non-inverting input socket. If there is not signal then the issue is previously where I said to look. I would dbl check TP5 and TP6 at the same time.
Everything works PERFECTLY! Thanks so much for the help! And it sounds really nice!! So good on snare & kick so far tested, driving the preamp and backing off the fader, really makes them pop!
now gonna build another one! at least I know what went wrong for next time =)
Please share to maybe help someone else in the future.
I went over every soldier joint and reflowed them and looked closely, It was ultimately the fader opamp not working correctly. I think. Suddenly it just worked, I'm not 100% what I did to fix it, sorry.
