Jeff, I'm not getting adequate signal from my VP26. There are three issues here. Sending a mic level signal through my lunchbox only comes through when my gain pot is set to full, and does not result in enough gain, the phase switch kills all signal, and the attenuate pot works in reverse where the pot set to 0 on the face plate results in a fully attenuated signal, and 0 passes signal. I have passed all tests listed at the end of the install guide, and am passing signal with both dynamic and condenser microphones, but the signal is distorted and requires the stepped gain as well as the input attenuate pot, (in reverse,) to be set to full. The output transformer is wired to the PCB properly, and I have also swapped out the pre built GAR op amp with a JH990C that I know is in good working order. I also know my lunchbox and the connections from it to my UA Apollo to be tested and in good working order.
Can you send me the exact link for the posting or page number on this thread that involves signal injection for testing the VP26? What other suggestions do you have for getting this unit to go?
