ccstudios said:I bought two pre built vp26s from a local engineer. He said that one or both had some problems and he thought it might have been the gar2520 opamps. I went ahead and purchased some ml2520 from whistle rock audio. When I tested the vp26s with either opamps, I would get clipping at low levels. And it's not clipping at all times..I know it's not clipping going into my converter. I read up on this thread and found out I should reflow the solder. I did that and put it all back together again, triple checking each component and solder joint...I still have clipping. Don't know what I should do now...any suggestions?
having the same problems, distortion on lower levels (sounds grainy and stuttered). when input is increased to almost 12 o clock it goes away and "normal" coloration begins..
how did you solve the issue?
tested with gar 2520 and red-25 opamps
is it normal that the input gain knob is very noisy when turned?
