EDIT: FIXED IN POST #728
Hello folks!
First of all great kit, documentation and all!
I have two VP26 kits and decided to build one at a time so if I made a mistake I wouldn’t double it. The first one worked perfectly except that the phase button seemed to change the sound somehow. I re-read this thread and noticed that other had had the same issue.
I have two Red dots so the problem shouldn’t be in them. Before I started to build the second one I checked the output transformer with a DMM as described in an earlier post. It was OK. Now I’ve finished the second one and the results are the same. Everything works great, but the phase button changes the sound. I’ve must have messed up somewhere again.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I’ve triple checked component values, and gone through soldering every joint again, but no change.
To exclude external issues I’ve tried different slots in the Lindell 510.
Different cables and audio interface inputs.
When I fed the preamps sine wave or pink noise there weren't any notable difference, but when I fed them some music everything cancelled out except a bump peaking about 4k. See the attached picture. The music level was at about -20db. It was same in both units.
So any idea where I should start looking for a mistake or is this a feature of the output transformer? Or am I just too paranoid…
Thanks for the help!
EDIT: I think I'm suffering the issue as gunner666 states in post#645. I've sifted through the posts, but it seems that it never got resolved?
-Tony
