Walrus
You have got the 10kOhm resistor in series with the LED haven't you?
If you are talking about the +/-V sockets then yes.When I'm testing resistance between the DOA sockets, it starts at ~500k Ω and then it slowly goes up until it rises over the range of my DMM (2MΩ).
Is that normal?
Awesome, many thanks, Jeff!If you are talking about the +/-V sockets then yes.
Could be incorrect resistor placement, wrong facing diodes, incorrect transistor placement and/or turning them the wrong orientation. This is most likely all a problem with the opamp itself and not the preamp.Hello,
I just powered up my VP312 for the first time and smelled burning. I removed the unit and noticed the DOA was hot. I'm pretty sure I just cooked it. Can anyone point me in the right direction to why this happned?
I have another VP312 with the same opamp. Should I try my questionable opamp in a known good preamp?Could be incorrect resistor placement, wrong facing diodes, incorrect transistor placement and/or turning them the wrong orientation. This is most likely all a problem with the opamp itself and not the preamp.
Rule of thumb, never test a fresh module build with a fresh opamp build.
Yes.I have another VP312 with the same opamp. Should I try my questionable opamp in a known good preamp?
Use Rev B docs for Rev C PCBs. The only difference was an updated square silkscreen footprint for the inout transformer.Hello,
I just received my first CAPI VP312 kit.
The PCB I got is a CAPI VP312-VPR Rev C but I can't find any overlay or BOM for a Rev C on the CAPI website.
Is it just like the Rev B? Because it looks the same but I don't want to make any big build errors.
Thanks a lot!Use Rev B docs for Rev C PCBs. The only difference was an updated square silkscreen footprint for the inout transformer.
It could be misplaced resistors?Hello there,
I've built many kits over the years and have recently built 4 VP26 / 4 VP312. All work as expected apart from one 312 which has a considerably lower output than the others. It doesn't sound thin, just a lot less volume, so I'm assuming (perhaps wrongly) that it's to do with the Bourns.
I have a good DMM but not much else - and I don't have much experience in diagnosing, so I don't know how or what to measure. I'm sure it's a bad solder join but any advice on how to narrow down the problem would be fantastic.
Thank you very much!
thanks so much for your speedy reply Jeff. I’ve double checked and all resistors are good. I built 4 units at the same time so odd that only one doesn’t work properly. I’ve checked the soldering and it looks pretty good. I reflowed all the joints on the bourns and the input transformer which didn’t help. what else could I look out for/measure?It could be misplaced resistors?
I would check the level at either end of the 1R on a good unit and then check on the problem unit with all controls the same. This could narrow it down to the output transformer.thanks so much for your speedy reply Jeff. I’ve double checked and all resistors are good. I built 4 units at the same time so odd that only one doesn’t work properly. I’ve checked the soldering and it looks pretty good. I reflowed all the joints on the bourns and the input transformer which didn’t help. what else could I look out for/measure?
Many thanks indeed! I’m sure it’s something simple.
