Thanks!I would check the level at either end of the 1R on a good unit and then check on the problem unit with all controls the same. This could narrow it down to the output transformer.
Good unit 1.85ohm
Bad unit 1.10ohm
Not DCR but audio level or ACV.Thanks!
Good unit 1.85ohm
Bad unit 1.10ohm
Apologies I’m not 100% on how to check that with probes! Either side of resistor or one probe elsewhere? Sorry I’m not very experienced with testing/diagnosing!Not DCR but audio level or ACV.
You need to run audio signal thru the preamp. Probe on the 1R with scope's ground clipped to a solid ground reference.Apologies I’m not 100% on how to check that with probes! Either side of resistor or one probe elsewhere? Sorry I’m not very experienced with testing/diagnosing!
Either side of resistor reads the same measurement for both.
Sorry for delay. The quiet unit reads around 5vac whereas the working unit is about 15vac. I used the same op amp for both but in the bad unit it gets very hot so obviously something up there!You need to run audio signal thru the preamp. Probe on the 1R with scope's ground clipped to a solid ground reference.
I can't recall if you said what opamps are in the units and who built them? If they were built from kits have you swapped them around or tried the suspect preamp with a good known to be working opamp?Sorry for delay. The quiet unit reads around 5vac whereas the working unit is about 15vac. I used the same op amp for both but in the bad unit it gets very hot so obviously something up there!
At this point I would suggest desoldering all leads for the output transformer, make sure no leads are touching each other, check DCR for each winding (should be around 9 ohms) and make sure no windings are shorted together.I built the op amps and yes I have swapped in a good one to check. They are 0252. I also checked the opamp from the suspect unit in a known working one and it appears to be fine!
Pink and yellow must be internally shorted. Please send me an email with order # and I will get you a replacement.Apologies for the long delay I've been so swamped! I tried some different combinations and found some weren't 9ohms. Is this normal?
Red + black 9ohm
Pink + yellow 0.30ohm
Pink + grey/white 9ohm
Yellow + grey/white 9ohm
Orange + purple 9ohm
Grey + white 17ohm
I had a similar issue- the problem was that I did not install foam tape under the input transformer (not included and not mentioned in the 312 documentation- I found out when looking at the VP25 guide). If your input transformer is too close to the board, it seems the PCB pads for your signal winding can touch the case and short out, sucking up all your phantom.Hey there, I just built 2x 312's and the pre sounds fantastic. I love it! I feel like it has way more mojo somehow than my VP26's & VP28's to my ears although I love the like hell too. With my Lovechilds it's bliss. However, on one of the two 312's I built the phantom isn't working. I examined both pres and they are identical and were built side by side simultaneously. When I engage the phantom on the unit in question there is a loud pop & then a powering up noise that leads to dead silence and no signal. I have been using the unit with the phantom disengaged and getting great sounds with dynamics but the phantom is a no go right now.
The leads on the phantom switch are in the correct position. The solders on the PCB connected to the switch look good. Before I start de-soldering and re-soldering the whole thing, are there any dead giveaways/go to's I can try first?
C
Replying to you as well, as this is the 2nd unanswered issue of this sort in the thread, and I was up a creek for weeks and reinstalled every component on that side of the circuit. I had the same issue, and the problem was that I did not install foam tape under the input transformer (not included and not mentioned in the 312 documentation- I found out when looking at the VP25 guide). If your input transformer is too close to the board, the PCB pads for your signal winding can touch the case and short out, sucking up all your phantom.Hi this is my first build and I m not getting signal with LDC mics. Phantom power led is lit when turned on but there is only 4.8v at XLR pin 2 and pin 3 and with no load it measures 12.6mA. All my dynamic mics are working so I assume there is nothing damaged in the input transformer. My shure sm94 SDC has signal but crackles a bit. My rack is a brand new midas L6.
Could be incorrect resistor placement, wrong facing diodes, incorrect transistor placement and/or turning them the wrong orientation. This is most likely all a problem with the opamp itself and not the preamp.
Rule of thumb, never test a fresh module build with a fresh opamp build.
Those caps aren't polarized so that isn't the answer. Unless you have a solder bridge and a short from when you soldered them.Jeff,
The 2520 on the top is the known good one (BC-Q2) and the one on the bottom is the one that is heating up and turning the resister dark in color (V4.1). R12 near the O pin is getting dark. Is it possible that I have the yellow caps CD1 and 2 wrong?
Good to know. I did put the bad DOA in the good preamp and the DOA was still getting hot and smelling bad. So I assume I did something wrong on the DOA. I just want to figure it out before I build another one.Those caps aren't polarized so that isn't the answer. Unless you have a solder bridge and a short from when you soldered them.
Look for a backwards or misplaced transistor(s).Good to know. I did put the bad DOA in the good preamp and the DOA was still getting hot and smelling bad. So I assume I did something wrong on the DOA. I just want to figure it out before I build another one.
I think I figured it out. I had BD 139-16 and BD 140-16 swapped. I didn’t realize they were different.Look for a backwards or misplaced transistor(s).
