Echo North
blueberryjam said:Mike,
Yes the ICs are correct, 71 on the main PCB and two 72s on the meter board. Everything looks like it's oriented correctly and I'm not seeing damaged diodes. When I got them there was a lot of flux on the PCB (bought them already assembled), so I thoroughly cleaned them up when I noticed something wasn't right with the GR meter. What's weird is that before cleaning them up, only 1 unit of the 2 had the bar meter issue, after cleaning they now both have it.
So on the bar/dot jompers by the 16 pin ICs you have nothing installed there correct? Just three empty holes?
Mike
