Echo North
rachansky said:Sorry for the delayed response. Work has been brutal lately!
5.92V at C7 with the qbias rolled off completely ccw.
Wow that super hot. Input set to mid?
andia said:Hi,
I got a non functional fet500 A on the bench.
I could trace signal to the gate of q4, after that no signal is coming through. Q4 seems to test ok, but i‘m not sure about that.
Does anybody have an idea?
Thanks, andi
Hairball Audio said:Always use the + of D4 as your common reference. With a 0dB signal and in and out mid way, what your VAC and C7?
Mike
andia said:Hi mike,
thank you for your time.
I measure 4.59Vrms at C7.
Thank you again,
Andi
Hairball Audio said:Wow that super hot. Input set to mid?
Hairball Audio said:What do you have at output tx brown wire?
rachansky said:Yes. Everything as per your previous message.
andia said:0.0Vrms :-\
Hairball Audio said:Still nothing significant on output brown?
rachansky said:Just to recap so you dont need to scroll back My output is super hot. I have good signal through the unit but when i get to the calibration of the meter bridge the ouput knob adjustment is so touchy I cant even dial it in to .388V output. Additionally the output knob seems to max out within about 1/8 of its range ( call it 2 hours on a clock as a range reference ). I ordered a matched pair, the other unit is working perfectly as far as i can tell, components have been verified.
Thanks again for your help in this matter.
James
rachansky said:Input tx pad 1: I am not sure which one is pad one but on card connection side of the input transformer starting closest to the output tx I get 0V, .072V, 0V and 0V
-ve side of C7 is 0.104V
output tx brown wire is varying in AC but in DC reads as 28.26V
Thanks very much for helping me out! I was almost ready to admit defeat and I hate that!
James
Hairball Audio said:Looking back at this. So I'm assuming the 0.072 VAC is the input secondary hot. This voltage is perfect.
But you say you have 0.104 VAC at C7, so this has changed and is now like 5 VAC correct?
What was your actual AC measurement at output brown?
Mike
rachansky said:My original measurement was made mid way through the calibration stage after I had adjusted the q bias and dialed back the output voltage to 2.45 VAC across pins 2 and 4.
Now with the q bias rolled all the way off my meter is ranging from zero to 19V AC or 31V DC between the brown and d4. Between pins 2 and 4 on my test extender I am getting .025V AC.
Hairball Audio said:So that would mean you have no or very low output if you only have 0.025VAC at your output + and -. I thought you said you were observing super high output?
rachansky said:Sorry that last post should have read 0.25VAC.
Maybe higher output isnt the best description, the sensitivity of the output pot is all within maybe 1/8 of its range. So after the q bias calibration when the output pot is used to cal the VU trim on the meter for example I am unable to come anywhere close to setting it to .388 VAC. If I simply touch that pot the output can go from 0 VAC to .7 VAC. The VU trim doesnt seem to have much of an effect on the signal either.
I hope this clears things up. I'm thinking about mailing this thing off to you as we seem to just be going around in circles here.
Hairball Audio said:That's with the controls mid way and 0dB signal...GR off?
You should have like 6+ VAC on the output.
You can always email us if you want us to fix it.
Mike
