dobrobson said:Double checked and they are. Not sure what happened but now I can't get the thing to pass any signal at all... may need to send these up your way to see if you guys can salvage them for me!
dobrobson said:No worries, I'm sure I just goofed something up. Still really enjoyed the build experience!
hillamps said:Just finished up my first Silver Pre this weekend. I love the open design on these that let you configure things on your own. I set it up to similar to a basic 2520 and loaded in a discrete opamp I had. Sound was excellant. I installed a dip socket under the opamp pins so I could test it with an IC op amp. All I had was a Radio Shack 741 generic op amp but I decided to give it a test. This pre sounds pretty damn good with a cheap opamp in it! I have some "audio" grade IC opamps on order from Mouser and now I can swap them in and out to see how they sound. I love this open design and the chance to experiment. I can still install a discrete opamp over the dip socket so I will also test out some discretes. I will be ordering more of these kits real soon. Great product for a technician/musician like me!
martinswain said:Hi Mike,
It's me again, the guy who posted issues with the Copper module all the way back on page 6 of this thread! Well, my Bronze module works, and I've used it on multiple sessions and love how it sounds, but still can't seem to get my Copper module to work.
I'm at a loss. I have reflowed solder connections on the input and output sections, reflowed solder on the Grayhill switch, checked diodes to see if they were broken, replaced capacitors and re-inserted the op-amp sockets. The issue I'm having is that the signal is really distorted, and will kinda cut out if 'too much' signal passes through on the higher gain settings. The Grayhill switch increases gain no problem, and the output pot turns signal up and down no problem.
Could it possibly be a damaged op-amp? I was thinking about plugging in the op-amp from my Bronze module into the Copper to see if I could rule this out, but didn't want to do so in case I damaged anything. Can I swap the op-amp over to check?
I'm an absolute noob at electronics, as you can probably tell, but I want to persevere and get better so I don't have to bug people all the time. Any help you could give (again) would be a huge benefit.
Thanks.
amcmaken said:I built a Bronze pre-amp and it's not passing signal from the mic input. I can confirm it sends phantom power. I've tried the pre with both dynamic and condenser mics to no avail. When I turn up the Grayhill (input) I can hear the gain increase, but no signal from the mic is getting through or being amplified. I texted the DI and it works and sounds great! The Grayhill controls that just fine. There is clearly some sort of disconnect between the input and Grayhill, but I've been over the BOM and Build Guide several times and can't find where I'm missing anything. Any suggestions?
Hairball Audio said:The relay, by default, is set to DI. If your mic input is not working but your DI is, it's because your relay is not flipping on. The relay has 8 leads, 2 of them are separated from the other 6. Make sure all 8 leads are soldered.
Also, check your resistors in the relay section and the diode orientation.
Mike
amcmaken said:Mike,
Thank you so much! I did manage to miss soldering two of the relay leads. My Bronze is working like a charm now!
Sometimes you're staring right at the problem, but just need to know where to look.
Hairball Audio said:I would suspect something external to start. What is your rack brand? Where is the power supply in relation to the rack space your pre is in? Does moving it to a space further from the supply help?
Mike
tctonn said:Hey Mike,
I finally had a chance to trouble shoot this and by checking all the components and reflowing a few joints. It looks like the noise was likely environmental. However...
The output signal is really, really low. It sounds good and if I boost it in my DAW the S/N ratio seems good. But the level seems to be 15-20db below what I get out of any of my other gear.
I've done a very thorough check against your build guides and a few pics of successful builds on here. Any ideas where I should start hunting?
dobrobson said:Got my two Copper repairs a few weeks back and happy to report that they are AMAZING. I'll be using my Pre73 as a doorstop from now on... thanks, Mike!!!
