Echo North
mrtomcat said:now that my bad copper is a great copperthe other copper has a bit of humming I noticed
It's not too bad, I can lower the input and up the output to compensate but since my other copper is absolutely noiseless I would like to try to get this one there as well.
I checked the slot and cabling and they are fine so it's definitely the copper itself.
The wires on the transformers are as short as it can be and the soldering is clean.
Other than that are there any usual suspects I can check on?
thanks
Is it closer to the power supply? Does the hum follow the unit? Try putting it in the slot furthest from the supply.
