shortyboyboy
Member
- Joined
- Jul 14, 2017
- Messages
- 16
Hey Paul,
Thank you so much for the reply. After getting stuck on a build like this it is very reassuring to know that there are people like you out there to help. . Okay, I'll run through it.
When I turn on the Lunch Box the Lola will pass signal through the Mic Preamp for 1 second and than will fade out. I am sure the preamp was working because I spoke into the mic while I adjusted the preamp output knob. In that brief time period I could hear the signal move with the output knob rotation. It also worked for a Phantom Powered Mic and DI input the same way.
To answer your other questions:
-I hear something inside click al little when I power up the lunch box. I don't hear any different clicks when I plug the DI in other than the normal sounds of plugging a 1/4" into a socket.
- I am not sure how to test the voltages to the DOA's (I'm a newbie). Do you have any youtube links on how to do this?
- Yes, I built the 2 JE-990's that Hairball supplied.
- I have not tested the IC's and Jfet's. I'm not sure how to do this either :\
- I haven't built the LED meters yet, because I'm at the testing stage before hand. Maybe I should?
When I put the pin inside of the Grayhill stepped gain knob I did as the directions said: turned it all the way clockwise (gain all the way up) and inserted the pin in at 12'o.
Thanks again, Paul.
Thanks again, Paul.
Potato Cakes said:Do the relays click when you insert the 1/4" cable? Have you tested voltages to the DOA's? Did you build the 990's? have to tested voltages to the IC's and Jfet's? Power is usually the first thing you should check.
Do the LED's on the meter light up when you try to run signal through it? Have you tried adjusting the gain settings? You may have some bad connection with one of the Grayhill pins and or it's resistors.
Paul
