jefflehiress
Active member
- Joined
- Feb 29, 2016
- Messages
- 31
djfatum said:The VU must have 200 micro amperes (1 milli amper too much)
iampoor1 said:This might be better in another thread, but what CNC are you using? Are you just engraving anodized aluminum? Love the look of your panel.![]()
Eliani said:Could you tell me what meters you bought and where you got them? I'm having trouble finding them.
Eliani said:Not to brag but i'm kind of proud of this build!
At least of how it looks because wiring could have been a bit cleaner, but I'm sure I'll get it next time. I'm waiting for new 6BA6/EF93 tubes to arrive, I've bought like 10 and hope to good pair out of them. I'm not totally aware of how one would match tubes, or if I even need to, but I'm guessing it wouldn't hurt as I can't seem to get C and B to the same voltage! This might explain that the input get's distorted when cranking the input?
I've yet to do the threshold/ratio range reduction mods
bernbrue said:Either you've got a bad output tube (12AX7) or your output transformer is not wired correctly. You should have the same voltage as on G.
Bernd
bernbrue said:E and F are not measured correctly.
Bernd
Bernd
