Hi!!!
I'm testing the first channel, it sounds lovely, but there are some strange things, the input attenuator, the transformer is a 8540 sowter (600 / 10k) with the same h-pad configuration as the output. Attenuates to the middle, from the center to the ccw seems to expand the sound (I do not know if it's a problem, the result I like) I've reviewed and everything is correct unless something happens with the H-Pad, you may not need it, any ideas? I have not clarified with the H-Pad calculator, which I put in Required Attenuation In DB (1 to 40)?
The VU, I used a Vintage-Meters VM-B10R https://www.don-audio.com/Vintage-Meters-VM-B10R-LED-Retro-VU-Meter-LED-Illuminated
and I can not put it to 0, it does not exceed -5, but it moves, indicates compression (and I hear it !!!) any help with this?
the release is noticeable and seen in the movement of the VU, the much more subtle attack
The voltages are OK.
Still sounds great !!! I think it was worth the investment in tubes
For 6ba6: 4 paired manleys
6av6: Heintz and Kaufman (nos) matched
12AU7: CC803 S matched tube amp doctor.
Great project !!!
Great project !!!
