Hey Gustav, I got a question concerning grounding... again ;D
I read your post on general grounding in the G-Pultec thread:
"General grounding:
- Power input gnd to chassis gnd.
- Wire XLR's pin1's together.
- Wire from xlrF(input)pin1 to input gnd on PCB.
- Also wire from this point xlrF(input)pin1 to chassis gnd."
I did it like this and like in your "Wire Guide" pdf, where only on the first channel input pin 1 is connected to gnd on pcb. And each additional channel pcb gnd is not connected.
But could it be that it would be better to also connect input pin 1 from the second channel to the gnd on pcb?
Or would that create a so called ground loop?
Because I'm starting to think that the buzz I hear is a grounding issue. The left channel (which has a connection between XLR and pcb gnd) is dead silent. But the right channel isn't.
And I noticed that the inductor in my AML ezMEQ-5 is also quite close to the power transformer and I get no buzz there...
Would be nice if you could elaborate a bit on this matter. This whole grounding thema is really confusing, especially because everybody seems to handle it different...
"General grounding:
