Matador said:
I wasn't addressing you: and I wasn't even think of you (or anything you may or may not have wrote 10 years ago) when I was typing.
I was address the OP's question of whether or not it would "harm" a tube or be dangerous to the tube to burn it in in-circuit: specifically about the possibility of current "runaway" which isn't even possible in a C12-like circuit. The OP seems to have an idea that only fixed-bias circuits can be used to test tubes which simply isn't true.
It is not exactly that way, my concerns were addressing the following statement by chunger in the official C12 thread:
[quote author=Chunger]
Note: It is imperative if you are following this "unscientific" initial verification process to make sure the tube and capsule that are being used for calibration and function verification are 100% stable, broken in, and functional. Otherwise, all manner of problems that are difficult to trace can surface. The 12AX7 tube that originally shipped with my HT-11A was a hissy, intermittent, crackling mess and totally unsuitable for even function testing. The Electro Harmonix 6072A tube used for function testing was fired up in a guitar amp for about a week and tested in studio to be completely stable in another microphone. If purchasing a nice NOS tube from Christian Whitmore for this project and you do not have a known, stable tester tube on hand, please consider sourcing a stable but cheap tube from him for testing purposes. . . perhaps a tube that is more microphonic than acceptable for microphone use, but is stable and good enough for setting up voltages and function checking.
[/quote]
So my question was not about the unsuitability of burning in in the C-12 , but actually the opposite: If the biasing of the SRPP output stage was appropriate to burn-in and test the tube, so I could have one to fulfill the "imperative" requirements in the C12 build thread.
I agree that it is possible to hard-wire the grid to test the noise, but that precludes that my C12 is already built, which it isn't. I am trying to get the path of less pain.
Thanks anyways!
