ELS
Active member
Well actually it's that I don't have any transformer that fits in my mic body, it's only 30mm ID, I previously used a gain-stage into a cathode follower which worked well, but I wanted better x)So it seems rather complicated. Maybe use a cathode follower? As far as I understand it would make things a lot simpler when you want to avoid a transformer but want to use tubes.
I wanted to use a CF-Gain stage circuit, removing the need for very high resistance resistors. but that would give me a high output impedance so I was worried about high end roll off.
I do have one transformer that fits but it's not a very good one, frequency response is rated @ 160-6.3khz
distortion is also terrible:
100-200Hz 4%THD
200-400Hz 3%,
>400Hz 2%
It doesn't say at what drive levels.
I do like Roy Brown's records so maybe the 6,3khz response will suffice
