In order to "judge for yourself", the capacitance itself means nothing. It must be put in perspective with the rest of the circuit, including tube output Z, xfmr ratio, load... My post was not about "see the flaws in your circuit", but a more holistic approach. If you don't like that, find for yourself, nobody owes you anything here.
As far as I know, no manufacturer cares to document that.
Can you read the title of the thread, "BV08 Transformer Capacitance".
The XY problem is BS because I didn't ask you to re-engineer my circuit.
I could put the capacitance value in perspective with the rest of the circuit IF I KNEW WHAT IT WAS. the U47 circuit schematic is easy to obtain.
So far the best answer I've gotten has been that it's less than 750pF
How can anyone know what Your transformer does ?
If you really want to know measure it !!!!
If you order 2 the same transformers from the same company built the same day they measure differently, that is what we call tolerances.
again, not my transformer, BV08 Transformer, as the thread title would hopefully suggest.
My view is that nobody knows, nobody cares, and it's close enough to being irrelevant that it doesn't matter. But once again, what do i know?
And the XY problem thing was more about you clinging on to this primary capacitance idea (the "Y"), while your actual concern is (or should be)... i'm not even sure what, but that's the "X".
"I'm not even sure what, but that's the "X"" It's because I haven't yet designed my microphone circuit, I cannot because I'm lacking details on a different microphone desing that I want to use as a rough guideline for performance, so I know how far my circuit's performance would be from that.
While the response of the U47 has been messured and can be found, I couldn't know how much of that is impacted by the winding capacitance of the primary.
Think of guitar pickups how the type of wire insulation on that strongly affects the response of them, they are usually wound with 42AWG wire with around 8000 turns.
The BV08 is wound with 41AWG wire with around 2600 turns.
So saying "It DOESNT MATTER", is most likely entirely false just by comparing the transformer to guitar pickups for which at least the fact that the capacitance DOES matter is clearly known.
