mihi_fuchs
I extended my microphones by a pair of C12 clones. The PCBs are fitting into the T.Bone SCT800 donor microphone, a relatively cheap mic which is easy to get in Europe for a very decent price (used between 65-120 €) and it comes with a PSU, which can be modified.
As noted in other posts, tube microphones run on high and letal voltage. Even after switching them off they may hold these voltages in the capacitors for quite some time. Therefore only work on these projects if you know what you are doing and bear in mind that you should handle these things with the care and attention that they deserve!
In the link below you can find a building guide, the BOM for the PSU board and the microphone PCBs as well as a sound sample of female vocals (thanks a lot to Julia Wohlfahrt) and a drumset (thanks to Michael Golautschnig).
https://www.dropbox.com/sh/i8lscny4iviod54/AABCSr61SJeYCGhqDt1QfZkIa?dl=0
Here are some pictures of the built:
For the capsule I chose a Beijing 797 Audio Co., Ltd. Cy039 and the transformer is a 3u audio GZT-12 transfomer. The tube is a TAD 12AY7/6072A Highgrade(provided by Banzai music, order# SKU51827). The sound sample was recorded in cardioid pattern. 9 different patterns are available (Omni > 3 intermediate omni/Card > Card. > 3 intermediate Card./Fig. 8 > Fig. 8). They are picked via the switch on the PSU (see pictures below).
Last but not least the project has been highly influenced and some solutions were simply copied from members of this forum (e.g. matador, khron, poctop, chunger, and others) - thanks for all of their posts, ideas and solutions that they have shared over the times.
As usual the remnant PCBs I got left from the order will go the black market if you're interested,
Have a nice time DIYing!
all the best
mike
P.S.: Here's the link for the leftover PCBs if anyone is interested:
https://groupdiy.com/threads/leftov...t800-donor-body-pcbs-only.81199/#post-1045760_______________________________________
Addition: PCBs with UTM transformer and comparison.
Out of curiosity I changed the transformer for the UTM0512 (larger in size). I had to adopt the PCBs as you can see below. The sound is very similar. However I observed a tiny bit more output with the UTM. Guess winding ratio is not 100% the same. I upload the sound files to the Dropbox link above. Also building guide and BOM have been updated and can be used for both versions. Schematics stay the same. PSU is also unchanged.
Mike
all the best
mike
Mike
