C12a mod to remove cathode follower?
It’s a diy version, hum starts as soon as I plug it in and hum is greatly reduced once valve kicks in, also polar patterns don’t really seem to do much on headphones
And it can only possibly be the fault of the type of circuit, not grounding or wiring or power supply filtering, or anything else..
I have followed the original schematic faithfully so I’m assuming that the filtering and the gnd scheme is correct.
My chassis gnd is connected to neg diode bridge on B+ side
well ive taken off the gnd from neg diode bridge on B+ and now i have IEC gnd to chassis and XLR socket Tab connected to pin1 and a connection from pin1 to the gnd at the 1uf/125v cap C11.
Hum is still there, so im going to try moving the toroidals and see if hum changes!
