Spencerleehorton
moved the toroidals out the case and no difference? hum still there
power transformer? Why?must be transformer then right??
I'm on the train, but that also sounds like 100hz to me, there's an offset current flowing between two loads, ground loop!i'll take a look at the transformer and make sure its ok, sounds to me like around 100hz frequency wise?
No, it could filtering in filament supply or lack of it, a h-k short in the tube. If the tube is cold and you are getting hum on turn on then it's not the tube. Pull the tube and see what you get.And it can only possibly be the fault of the type of circuit, not grounding or wiring or power supply filtering, or anything else..
