Can someone help me? with PSU and schematis /SSL SL 502
javierboz
New member
Hello,from Spain
(Sorry but my English is not good)
I have a two SSL SL 502 EQ modules,I want to built me a rack with a good power supply.
I Know tha the best is Keith Skerret,his web:
http://www.recycledaudio.co.uk/outboard02.php
I find neither a lot of information nor schematic..........
Can someone help me? Somebody have the schematics of SSL SL 502 EQ??
How I can do a good PSU ??
Thank you.
It's in the groupdiy account, under sent, 3-19-06, check the metameta how to get there.
Have you bought these racks from recycled audio? Looks cool, I wonder if anyone has really used one and can report about the quality?
Michael
I don't know about their rackenclosures, but I've once bought a couple of those lunchbox printed boards. The quality of the boards is excellent, but there's a pinout mistake in one of the S502 links (which took a pretty long time to discover...... !). But for balanced straight in and out wiring, they're fine. Keep in mind that the connectors doesn't come with the board.
PSU for SL502 ? JLM audio 5 rail powerstation plus a 2x24 volt torroid.
http://www.jlmaudio.com/shop/index.php?_a=viewProd&productId=12
SSL SL 502 should be powered with +-18V . Even if I know that SSL power supplies use often 7818 and 7918 regulators, I could design a power supply for these two units but first all I should know the SL 502's supply max currents and nominal supply voltages. However It's easy to design.
Pier Paolo
Finally,Mr.Cyril Jones Raindirk,He has made me the rack for both modules SSL SL502 EQ.(with illuminated Switches,bypass,PSU internal,...)
The work is impressive,as you can see:
Thank you,Cyril.
