> Is the quality of PC-clones a good source to build other gear with?
There is no 60Hz power transformer.
The whole 20KHz transformer and driver affair is designed for the 5V and 12V outputs, and will need excessive hacking to get more audio-useful outputs. Also many of these things won't start under a light load (most audio is "light" compared to the 150W-300 watt ratings of these boxes), and they all put out huge amounts of slightly-supersonic trash to crap-up your audio.
They also store high voltage on uninsulated parts for maybe hours, maybe days (though usually no more than a minute). So before you open one, un-plug it from the wall and take a nice long tea-break. If you are SURE it has been un-plugged since the P-II died, tear right in. However with 386-era supplies that have been un-plugged for more than a few years, there is some chance the caps have decayed. They can burst when power is applied. Find the old hard drive (bigger is better) as a dummy load, take the PS and HD outside on a concrete patio, and plug it in with a long extension cord. If no smoke/boom in an hour, and the drive is spinning (or trying to), then it is probably good.
Every standard PC supply will yield two 200V filter caps, typically 100uFd-470uFd depending on original cost. If you have a 150V rail to smooth, these are fabulous.
You can also salvage several 6V or 16V caps in the 100uFd to 1,000uFd range, clustered around the output wires.
The heatsinks can be useful; also the power entrance connector.
The controller IC is good for general purpose PWM, but new ones are so cheap it is hardly worth ripping one off a board.
There are two sets of power devices on the heatsinks. Toward the input side are two 400V transistors, but they could be BJT, FET, or IGBJT, and won't have any standard part-number so you can look them up. Good luck. The parts on the other sinks are high current low voltage fast rectifiers in transistor-like packages-- if you need a fast 50V rectifier you can play around with these.
There are sometimes one or two linear negative regulators like 7912, to derive the low-current -12V and -5V rails defined in the IBM PC standard (BTW, in all my years I've only seen one card eat -5V).
There is usually (in old good supplies) a thermistor in the AC input, before the main wall-power rectifier, to limit inrush current. These could be handy in any big supply that dims lights when you flick it on.
