blue_luke
Hello all!
JR said that "back in the 80s I designed a piece of semi-pro test equipment (TS-1) and that was harder than I expected."
Well!
I am swimming quite vigorously these days!
Understanding exactly what he means!
It is true, I find designing test equipment is an art in itself.
So here is my offering for the input section of the test set I am trying to design.
I am talking here from the output of DUT to the line input of the Sound Card.
Looking at this schema, I think I have felt to the "while we're at it" syndrome
Mind you, as a guitarist, after 21 guitars and basses I still need a few more and I am also afflicted with G.A.S, the Gear Acquisition Syndrome .
Boaf! it's only money, and having fun implies money. Sometimes rather lot of it!
So here it goes.
The schema is a mash of many ideas gathered here in our discussions, from Pete Millet and AbbeyRoad D'enfer point of views, some recommendations by Ruffrecord and all... And of course some of my own ideas!
I build my preamps, microphones, speakers, amplifiers etc...
So the versatility of the test set is rather important.
Let's beat this schema to pieces and see what we can come up with.
For AbbeyRoad_d'enfer, I retain your Idea that there should be a filter in the system. I have looked at your own schema and I think I can, maybe, get a bit further. I am not saying anything now, still in the conceptualization mode for this important section that will come later.
But I fully agree that there should be a set of filters in the circuit.
Also everybody, remember I wanted to keep this thing 'simple'
Well, I guess this has gone out the window!
Note: not all the components are not calculated as of yet. Since I use KiCad for my projects, I found that it is quite faster to select a part, assign a PCB footprint and then simply copy/paste the part as needed on the schematic, instead of constantly go thru the process of selecting a part, assigning a value, then a footprint. Resistors are resistors, and caps are caps... on with it. So you may find that some values don't make sense.
Don't fret!
Luc
Well!
So here it goes.
Don't fret!
Luc
