radardoug
Disconnect the summing amp from the bus. Is it clean? Then its a bus problem or a module problem. Remove all modules and add them in slowly. Does the noise increase as you do so? Its a bus problem.
The aux masters and buss amps for the auxes are in 5 separate modules, 2 aux masters per module.radardoug said:Have you done the test I suggested to you where you isolate from the bus? I presume all the aux bus amps are in a module together. Have you verified this module is correctly grounded and supplied with power?
radardoug said:You need to disconnect the bus from the bus amp, and see if it is clean. That way you can tell if the problem is on the bus, or in the module. Then add an input resistor to ground which is bus resistor divided by number of channels. That will force the bus amp to its normal gain. If its still clean, your problem is in the buses.
"bus"pucho812 said:wait I am confused here, so speakiung generically each channel should have a buffer for each aux send. From there It leaves the channel down the buss to the master where there would be another buffer and an amp before it leaves the console correct. there may also be a buffer in the master module to drive metering and such.
are you suggesting taking as measurement post buffer pre bus amp?
