No. All I said is some of the benefits of the capacitance multiplier are lost because of the protection resistor
That is intentional. It sounds better with that 100R resistor, after testing.
Current limit could be applied differently. If we, for arguments sake, use a standard current limiter, the output impedance at 50mA becomes ~ 7 Ohm and the 10kHz PSRR with Ferrite bead instead of resistor is over 100dB.
We can also omit current limiting entierly, , in that case the DC output impedance is ~ 1.4 Ohm.
The circuit I presented was optimised for reliable ability to be replicated by "average DIY'ers" while offering good performance to kill main based linear PSU ripple and avoid the kind of "sound" simple tube circuits produce when fed by power supplies optimised for lowest internal impedance using active solid state circuits.
It was never meant to be optimised for HF behaviour or maximum ripple rejection or lowest output impedance, non of which, in this application, have reliable correlation with reduced subjective fidelity impairments.
OTOH, the absence of protection resistor probably makes it a stiffer voltage generator
And maybe easier to destroy with a slipped probe during service or if the turn on sequence is out.
It makes for a less reliable circuit, especially if taken out of it's original specific context and treated as "general" building block.
Again, a lot in design is a compromise informed by the actual design purpose. Showing a simple circuit that should be able to be reliably replicated and applied generally as building block by Amateurs with limited experience and instrumentation had different requirements to taking such a circuit and carefully designing it into an overall product ground up and carefully testing edge cases to assure reliability in production.
Thor
