Capacitor tolerance important?
dustbro
New York - USA
Can someone enlighten me on the importance of electrolytic capacitor tolerances? What would be the sonic impact on some of these DIY projects if a cap that had a 20% tolerance was used over a cap that had a 5% tolerance?
thanks for any info.
For audio coupling, tolerance isn't that important as long as you are sufficiently above the point where circuit impedence and capacitance form a high pass filter. If you were right on the edge, then a low tolerance might push you below that point and the circuit could affect low frequencies somewhat, but that is rare these days, at least in my experience.
Now for oscillation/clock circuits and things of that nature tolerance is much more important and the highest tolerance and quality tempco are important. Not a lot of that in analog audio though.
In about any reasonable application electrolytic capacitors simply need to be "large enough" (this is different from e.g. film capacitors which often need to have a very specific value, e.g. for an EQ to get the right frequency). Hence good designs usually overspecify the value. This means that better tolerance than 20% will not improve anything.
Samuel
[quote author="Svart"]Now for oscillation/clock circuits and things of that nature tolerance is much more important and the highest tolerance and quality tempco are important. Not a lot of that in analog audio though.[/quote]
I dunno...
Most Parametric Equalisers are just down-tuned oscillators really: look at Jakob's Calrec version. In these cases, capacitor tolerance error translated directly to center frequency error. -If you can tolerate a stereo EQ pointing to 1kHz, with one channel actually centered at 1200Hz and the other channel centered at 800Hz, then ±20% will suit you fine.
Me, I prefer a bit more accuracy, so for all such circuits I buy closer tolerance, low thermal drift caps, and then hand-select.
Keith
Keith,
do you find you have to go through many caps to get matched sets? I'm actually hoping to build a Calrec eq with rotary switches and have been wondering about this,
thanks,
Ruairi
Keef, yes of course, I did mean that high tolerance caps should be used in gyrators and other types of tuning/oscillation circuits. I guess I should have said so, I didn't make that clear.
Yeah.. for anything tuned, the type of cap requirement that Svart mentioned is important.
I usually find that hand-selecting I get a 50% rejection rate. I'll surely them somewhere, as Make-up values (If I find some 10nF caps that I can't use because they're 10.5nF, that won't stop me using them to make 220nF if I measure a cap at 210nF... basically 0.5nF is a significant error as part of 10nF, but insignificant in relation to 220nF.
Basically, for most of my designs, I make all PCB layouts for timing-or-tuning-critical locations "parallel-available"
-Hope that makes sense...
Of course, my local component supplier has open bins, so taking the cap meter down to the store makes the number of 'spares' that I buy much smaller!
Keith
Thanks for the replys guys! So I can assume from the above posts that a proper rated Electrolytic Cap with a 20% tolerance will do fine in my Gssl.. right?
thanks again!
