It’s been discussed ad nuaseum at diyaudio where there’s other very smart EE types there.
https://www.diyaudio.com/forums/tubes-valves/216543-eliminating-cathode-bypass-caps-set-amplifier.html
Hot topic of tubes built in feedback
https://www.diyaudio.com/forums/tubes-valves/178688-triode-plate-resistance-internal-negative-feedback.html
The problems with generalizations is that we are usually talking about at least 2 stages of amplification. And if you’re using feedback around those 2 stages one needs to consider the poles and zeros or at least know about bode plots/theory.
Not to mention, impedance and that changing 1/2 of a whole circuit will affect the other 1/2. I think CJ mentioned that tube preamps were designed to have less tubes bc of some VAT tax on each tube, so bypassing gave more gain for the bean counters.
The REDD.47 ef86 is partially bypassed and I read about .5% THD difference from the fully bypassed input tube. So yes unbypassed achieves less THD.
Rod Elliot has some insight on partially bypassing too:
http://sound.whsites.net/valves/bias-gain.html#s2
