Hi All,
I had a couple of questions re the LA-1D so I thought I'd resurrect this thread to keep all of the info together, as this thread contains some great stuff.
I have a pair of original AGC-1D's here and I am in the process of constructing a 1RU breakout box to add the extra release times as per the LA-1D schematic.
I have found a 5 pin novel connector that is the correct diameter for the fuse holder, so I will move the fuse inside on a bracket and add the connector to an external box to avoid punching new holes in the front panel.
I saw above that Doug used a basic switch for the release times, so I presume the control voltage is nothing significant. I had a look at the spec sheet for the 6AL5 but if someone could advise the sort of max. voltage the switch will typically see, would be great.
I'd also like to bring the ratio/threshold pot out via this 5 pin connector too.
Can anyone see any downside to this? Voltages OK here too?
Thanks for your help!
Matt
