Hey ya'll. I need some of the pro's to check this mic preamp design layout before i make some boards. its nothing special at all just out of the INA217 data sheet.
Anyways it will consist of 48v on off switch, phase reverse, -20dB pad. Balanced output and a send output which will eventually go to a compressor i design. The compressed signal will then go back to the line driver for balanced output or with a jumper can be used to send two signals, one compressed, one not.
The board 3.5in X 3.5in. Hopefully will be something ideal for putting together a 3ru, 8 ch pre , or a 4ch pre. So input would be great.
thanks
[/img]
it 2 sided. I ran most of the signal on the top layer in red. all film caps are 100nf at opamp supply pins. Con3 will go to a grayhill selector for mic pre gain.
thanks
![a2-1.jpg](https://proxy.imagearchive.com/7ea/7ea21a51147cf754418df399206ea05e.jpg)
