shot
I know this is probably trivial question for most of you, but as a self thought enthusiast I couldn't find a place where this is explained, so I have to ask here for some explanation.
I want to put a simple passive high pass filter at the output of a unit I've built (CLX-VU to be exact), since I have some problems with sub frequencies it creates when processing low percussive material. The amount of energy below 20hz is too much and is triggering other dynamic units in chain needlessly.
So I'll strap a RC filter at about 15hz at the both output pins.
And here's my question:
If I go and calculate this filter using passive HPF formula fc= 1 / (2*pi*R*C) I can get 15hz cutoff using 100nF cap and 100K resistor. But the same frequency can be obtained if I use 100uF cap and 100 ohm resistor!
What is the practical difference?
I know both will work.
My gut feeling gears me towards 100nF film capacitor rather than using bigger 100uF electrolytic, but I want to know more!
Or is there any other R/C combination that for some reason is more adequate in this situation?
Line output where I'm putting this filter is impedance balanced and is used mostly on unbalanced insert of my console (so going back to console's insert receiver) but sometimes it will be driving daisy-chained into other gear's input. If that is to any concern when choosing values.
Luka
Luka
