sr1200
I recently put together another Royer Tube Mod from an MXL 2001. Ordered the Jensen db/e trafo, then heard nothing back from them for a matter of weeks. In the interim, i found something close (the CM-9766 from cinemag). The Jensen actually wound up showing up at my door about 2 days before the cinemag. Since my other Mod mic had the jensen, i decided to make a pair of the same instead of going w/ different parts.
I hate returning stuff, since im a packrat and usually find a re-purpose for things. But Im at a loss for this one. Can anyone think of a project I could use this for?
I have a C-12 kit on order with Chunger, but ordered the AMI transformer with the kit (probably more suited anyway).
If anyone saw my embarassment with the Rode NTK, would be kinda cool to make a circuit with a trafo to replace those guts...
If anyone has been looking to buy one of these, let me know before you get one from CM, I dont mind taking a bit of a hit on it.
specs - CM-9766 - 21.6K:150 (12:1) +28dBu Condenser mic output transformer for moderately high plate resistance tube circuits. Faraday shielding. CM-9766.pdf
