HellfireStudios
There is a volume drop of around 12dB, but the loud sources you tend to record with those mics won't be an issue with decent preamps. I do use the impedance matching resistor with the transformerless SM-57. Again, there is a slight loss (1-2dB) with the resistor in place. If the preamp won't give you what you need, get a better preamp...
I second the Sennheiser eSeries. I got massive guitar sounds with the e906 (similar to the e609 w/ a bright/flat/dark switch), and amazing metal kick sounds from the e902 (paired with a homemade subkick).
On the issue of the mic clipping on loud sources, are you certain it's the transformer saturating? It could be the voice coil.
BTW, you can use the inline impedance matching resistor on any mic that has a 150ohm output impedance (Audix i5, e609, etc.). You can even try it with transformer-coupled output mics (the real reason for the 2P6T switched version) for a type of pre-EQ. My earlier warning about phantom power with these resistors still applies.
-James-
-James-
