Ian MacGregor
I've been thinking about a mod to Gyraf's SSL to make the meter move to left with GR instead of to the right. Other than turning the meter upside down (haha) does anyone have any ideas?
So far, I've thought about biasing the meter to always be FSD with no GR, and then using a NPN transistor to short across the meter. The transistor would be driven by the op-amp that drives the meter in the original Gyraf circuit. For higher GR the op amp output voltage goes higher, making Vce of the transistor lower (which makes the voltage across the meter lower as well becuase Vce is in parallel with the meter).
With no GR, the meter is fed the 1ma for FSD. At full GR, the transistor is pretty much saturated and the meter is shorted out by the transistor. I guess the hard part might be for all the values besides full GR and no GR.
Does this make sense?? If it does, then I will do some calculations and test it out. I just wanted to make sure it wasn't a stupid idea before I spend too much time on it.
...or I could just turn the meters upside down... hehe
Thanks!!
Thanks!!
