The noise performance of these chips is heavily dependent on the Rin and Rout resistors.
Using 30k for Rin/Rout (the largest recommended value for the 2164) gives the worst noise performance, while using 7k5 reduces output noise by up to 8dB in Class AB mode or up to 12dB in Class A mode.
Further still, those resistor values need to be divided by the number of VCAs if you're using multiple sections in parallel, in order to actually realise the noise improvements of that arrangement.
Unfortunately, the measurement thread linked above doesn't seem to mention which value of resistors were chosen for Rin/Rout in those tests.
The attached images are cropped from the SSI2161 and SSI2164 datasheets.
