micaddict
I see one in-depth reply in this thread.
And no one who dares to challenge it in-depth.
Sammas said:The article is garbage. It is no different to those free walking tours that you can do in cities around Europe. Highly entertaining? Sure. Gives a few vague insights to the past? Probably. Worth throwing them a few bob as a tip at the end? Perhaps... but fast and loose with the truth in the name of entertaining people.
Science is about nuance. It is about the fine detail. It is about hard data that people can cross check, analysis and form their own hypothesis and conclusions from. That article contains no hard data. It has no references. And any person who is sick of the politicalisation of the topic should be demanding much better, and condemning such articles to the waste bin. People should be sceptical. People should keep an open mind... but not so open that your brain leaks out. That article raises more questions than it even tries to answer.
What is their actual stance? Do they even have one? Or is it as vague as something like: temperatures on Earth have gone in cycles in the past? "Our planet seems to be in a cycle of constant change"??? Are they writing a school assignment? The planet IS in cycles of constant change, a reality that isn't missed by any climate scientist. The actual crux of the argument exists in the cause and effect... and even their attempt to document it disproves their fundamental point.
Just take their graph that brightly indicates 'Whenever solar radiation decreases and volcanic activity had increased, global temperatures SUDDENLY plummet often within weeks or years". "a 500-Year plus span that extended from the early 1300s to the mid 1800s. During that time, there was little solar activity, or solar storms, which scientists refer to as the “Maunder Minimum.”
The Maunder Minimum occurred between 1645 and 1715 and was a period observed minimal sunspot activity. The first solar flares weren't observed by humans until the Carrington Event in 1859 but they are closely linked in occurrence, both the result of magnetic field interaction on the Sun. How can the Maunder Minimum be associated with 'Temperatures suddenly plummeting" three centuries before the event actually took place? The event occurs during an upward temperature trend on their graph? It literally indicates the opposite of the conclusion they are trying to draw.
Why is that even remotely acceptable? Why shouldn't it raise more questions? Have they just glanced over it? Does their graph include a degree of smoothing? If it does, why did they include the effect of the 1991 Mount Pinatubo volcano eruption at a much more microscopic level? Is it because it just fits their conclusion? Why didn't they explain the cause behind volcanoes reducing temperatures (sulphur based aerosols and debris in the troposphere and stratosphere restricting light penetrating to the ground)? Was the consequences to life of eruptions like Lakagígar not worth a mention? Are they really trying to suggest that we are all going to be fine because the volcanoes are going to erupt and reduce the temperate? The graphic does seem to imply that conclusion... despite the data not actually correlating in a way that supports it.
The article is TERRIBLE. Climate, and climate change is complex, and that article is nothing but a hatchet job, politically motivated puff piece.
