Walrus
No just the one, I borrowed it from a client, so even though he was happy for me to do it, I didn’t want to have a problem!
Not only that. I guess Shure engineers could have designed a proper circuit , just like SE, Superlux, Royer, Sontronics and many others have.Don't know if anyone saw this, but Shure seems to have licensed Cloud's "Technology" to put their circuit into the new SM7dB version of the SM7. I would guess Shure licensed the “tech” to avoid a (dubious) patent issue.
They are a “lifestyle” company now. Their biggest growth is probably with streamers and podcasters.Not only that. I guess Shure engineers could have designed a proper circuit , just like SE, Superlux, Royer, Sontronics and many others have.
Instead they decided to capitalize on commercial synergy between two recognized brands, just like Tesla with Bose or Ferrari with JBL.
Unfortunately, that could be said of many companies, Nike, Tesla, Apple...They are a “lifestyle” company now.
These graphs are done with a zero-ohm source impedance. With a typical 150/200 ohms source, the HF response should be lessened. Anyway, good enough for audio.Sorry for being late, here are the schematics I did a few years back + curves
All companies are money companies, it's their essence.Or even more accurately, they're money companies. Money for themselves and/or the shareholders, that is - whichever the case may be.
Actually No - I choose 200R as Source Impedance (but I didn't remember to tell Micro-Cap 12 to write it on the print ...)These graphs are done with a zero-ohm source impedance.
I always treat parsitics as separate explicit elements, in order to avoid confusion. Whatever computer resources savings result from using implicit parasitics are usually negligible.Actually No - I choose 200R as Source Impedance (but I didn't remember to tell Micro-Cap 12 to write it on the print ...)
Per
I agree. Spice works well for passive circuits...Oh - I do Not consider Spice (or other simulations) 'the Truth, the Whole Truth and Nothing but the Truth'
But MicroCap has served me well for years - especially to tune Filters and DC + Gain Levels .... where something like a Switcher, might be far from Real Life experince ....
With the aforementioned capacitot values and Zs=50r, the response at the input goes to nearly 2MHz, so the actual response at the output is governed by the 6.8k resistors and the test equipment input capacitanceI don't remember f0 on the real CL-1 .... except it was much higher than I expected it to be, with ZG = 50R ....
Get a lawyer to write enough ******** in Klingon language about how electric field moves particles, and you can file a patent for a resistor.
did you test it? last time i found out that jfet drains are not perfectly able to work into 1.5k mic input (and 5 meter cable) at high frequencies - i had something like -0.5db at 16k (or even lower). it was different circuit though - jfet differential with current source (low distortion, pretty clean). they suggest additional floor above with pnp bjt pair for outputSorry for being late, here are the schematics I did a few years back + curves (one of those are the new Texas Instrument 'Wonder JFet' (or so I seemed to remember) - so that one also has another value for the common Source Resistor ....
The 3n3 is measure in circuit, with a very accurate meter (accuracy might be lass than optimal in this situation) and without Power on the Circuit.
Per
It's not really an issue of "drains are not perfectly able to work into 1.5k". The HF loss is the result of the input being driven by a very high impedance. Remember the output Z of an open-drain stage or a cascode is very high, the FET being in "pentode" region, so the output impedance is actually 13.6kohms (the result of the two phantom supply resistors).did you test it? last time i found out that jfet drains are not perfectly able to work into 1.5k mic input (and 5 meter cable) at high frequencies
yeah there may be some filtering caps, zener protection or something else at the mic input. also cable capacitanceThe capacitance of the mic input results in HF loss.
yeah this is what i meant... i guess... thanksThe HF loss is the result of the input being driven by a very high impedance
