[quote author="PRR"]Keep your eyes wet...They get oxygen mostly from the air.[/quote] Most interesting!
Astigmatism is, in principle, perfectly correctable
You bet! I used to have 20/15 vision with my glasses and I could shoot a target rifle with great accuracy IF I got my "eyeballs" on just right...Haven't tried this in a few years though...
> why are those little tiny components an improvement?
Are they an improvement?
Here's my take on this, if anyone's interested.
SMT is an improvement...(overall, not really but keep reading), as PRR says regarding parasitic effects and such because of tight layout. It is touted in manufacturing because it is an "easier" process once set up. You load up the machine with PCBs, parts, and the locator program for the design you are doing and if the hot-air reflow oven is in tune, your yield will likely be >98%. A lot of money can be saved in manual rework costs. The machines that do this can be expensive, but they show up for work every day, they don't take vacations, they can work 24hrs...etc.
Otherwise SMT is inferior in many respects: Thermal capacity, service-ability, trouble-shooting, danger of stray solder bridges, etc. When was the last time you encountered a ckt that took hours to troubleshoot and it turned out to be a cracked
thru-hole cap? Tons of hours have been spent on cracked SMT resistors and caps...not visible until you hit them with an iron...then its obvious! Doh!
Typical SMT designs are going to take up less space but the PCB designer has to think clearly to avoid vias which can consume a "lot" of space. Vias are sort of built-in when using thru-hole.
Btw, that part about thru-hole giving mechanical support is IMO only going to be true for a PCB with
plated thru-holes. Single-sided PCBs...you are at the mercy of the bond between copper and the PCB substrate...sometimes its good...sometimes, its just not. Sometimes, its okay until the PCB gets cooked for a few years. I've got a Samson headphone amp in need of some simple repairs, but I'm afraid to touch it for fear of every trace in the middle of the board falling off because the o/p devices have cooked the traces and they are ready to fall off!
HTH!
Charlie
