> I thought they forgot to put something in the plastic bag
People with eyes younger than mine can see and even hand-solder those things. But four of them could dance on the tip of my regular solder iron and I wouldn't see them.
So you don't need an SMT factory, but you probably need a teeny iron, a strong no-hands magnifier, and if you are much past drinking-age, a young sharp-eye kid to do it.
BTW: if you have an old 35mm SLR camera, the 50mm lens is an excellent 5X magnifier, much better color correction than a simple lens. Hold the film side toward the tiny object, about 1.5 inches away, and put your eye about 10 inches out from the face of the lens. Adjust lens to object distance to find focus. Lens to eye distance is fairly uncritical, as long as it is much more than lens to object distance. The 30mm wide-angle lens may be a stronger magnifier, but fish-eye (super wide angle) lenses may distort too much for comfort. Telephotos are useless: a 250mm lens is a 1X magnifier, and a 125mm only 2X. If you hang around serious photographers, especially small-format darkroom geeks, a short enlarger lens (like 25mm) is really good and often not worth much if the photographer has a "better" one in her collection.
But camera lenses need a third or fourth hand when soldering. (You could screw it into a hole in a thin board, and prop the board up over the object. Need to get strong light under there too.)
And camera lenses, all simple lenses, have a basic problem: the shorter the focal length, the stronger the magnification, BUT the closer it has to be to the object. So it is hard to get light or the soldering iron under a strong lens. Worse with camera lenses, because they are multi-element (but designed to work as a simple lens). The effective center-point is inside the body of the lens, so the back of a 50mm lens needs to be around 30mm from the object.
The way to get a close-up view from a distance is telescope or binoculars, a 2-lens system. Of course most telescopes are tuned to focus from Saturn to the neighbor's window, not to the workbench, and are bulky. They do make head-mount binoculars for surgeons and other fine work, but they are not cheap. (Not to be confused with the simple $19 head-mount simple-lens magnifiers.)
