I looked at the Toshiba transistor they specc'd. It showed a typical VCE(sat) of 0.04V.
Which is quite a bit lower than the PN2222A's 0.3V!
/R
/R
Rochey said:the base is driven by a constant voltage through a fixed resistor.
Rochey said:However, your right regarding the collector current. However, I thoguht that VCEsat was set by the base current?
nahRochey said:John, I'm going to make you look at that schem again...
nahthe base is driven by a constant voltage through a fixed resistor.
/R
Rochey said:Looks like it's performing a gain switch? (switching a resistor into circuit).
JohnRoberts said:Ewww you tricked me into looking at a Behringer schematic... :-[
No, because there's nothing to even out. You want top performance, you pay the price. That's like saying a carbon mic is suitable for today's music production purpose, because it's cheaper than a Neumann.jdbakker said:abbey road d enfer said:I've used a lot of DG308/411 with success, the latter being much better than the former. They are at least an order of magnitude better than the venerable 40xx.
They're also an order of magnitude more expensive, so that about evens out.
abbey road d enfer said:No, because there's nothing to even out. You want top performance, you pay the price. That's like saying a carbon mic is suitable for today's music production purpose, because it's cheaper than a Neumann.jdbakker said:abbey road d enfer said:I've used a lot of DG308/411 with success, the latter being much better than the former. They are at least an order of magnitude better than the venerable 40xx.
